Log in Sign up
Posted by Bryan Liu
Technology is powerful! It has an ability to make lives simpler, convenient and enjoyable in many ways. However, technology is changing rapidly each day so staying in pace with the trends can become quite difficult. It would not be exaggeration to say that technology has made it possible for lives to be more comfortable.
No matter where you look you will come across people with smart devices, right from smartphone and tablets to fitness watches. People have become used to traveling with devices and using them anywhere and anytime. One of the challenges of moving around with different devices is keeping them charged all the time. When you are traveling, finding an outlet to plug in the charging adapter may not always be possible. Along with tech devices, you also need to invest in innovative devices designed to address these issues.
Here are the top 5 tech innovations of 2019 that you need to look out for -
SuperTank Portable Charger
A 27,000mAh ultimate power bank, Zendure SuperTank is powerful, portable and easy to use. It is especially useful for quick charging USB-C power output devices, a feature most power banks in the market lack. It packs up to 100W output in a single port, enough to fully charge a MacBook Pro in 1.5 hours. With its capacity of 27,000mAh, it can also double up the battery of your laptop. This power bank comes with 4 USB ports so you can charge 4 devices simultaneously. Along with laptops, it can also be used to charge compatible security cameras, LED lights, projectors and more. With just a one-hour recharge, this power bank can work endlessly for a week. Undoubtedly, it is a reliable travel companion for your devices.
27,000 mAh portable charger with dual USB-C PD (100W + 60W) & dual USB-A ports, quickly charge MacBook Pros & other compatible devices
Q4 Luxury Wireless Charger Bundle
An ultra-portable adapter, the Q4 Luxury Wireless Charger Bundle is one of the most pocket-friendly wireless charger bundles available in the market. This is a rub resistant, fireproof, waterproof and air permeable wireless charger is the true definition of luxury. The 3.0 AC charging adapter has a unique luxury Alcantara surface. The adapter provides fastest charging speed and is compatible with the latest iOS and Samsung devices. Carrying this adapter around is also not a hassle as it charges through lightweight cases made of plastic. The charger bundle box comes with a USB to micro USB cable along with the adapter and wireless charger.
Maximum Wireless Charging Speed: Provides fastest wireless charging speed for compatible iPhone at 7. 5W, Samsung at 10W (all other Qi-enabled devices up to 10W)
SuperCord: Durable USB Cable with Lifetime Warranty
Tired of the rate at which your USB cable gets damaged? The Zendure SuperCord is the answer to all your USB cable wear and tear problems. It is a super durable USB cable that you can easily carry around with your charging adapters and power banks. Stylish and durable, the cable has been designed to provide superior strain relief and integrated leather strap. The most unbelievable part of this cord is that it comes with a lifetime warranty. Stay assured, incredible and durability of this cord will be intact in your fast-paced life. Leave your worries about broken and damaged cables behind with the SuperCord.
Durable Nylon Braided iPhone Charger Cable Compatible with iPhone Xs/Max/XR/X/8/8 Plus/7, iPad Air, iPad Mini, iPad Pro, iPod Nano, Black
Passport Pro: The Safest Global Travel Adapter
One of the first grounded travel adapters that comes with a resettable fuse, Passport Pro is a truly global travel adapter. Launched in 2018, this adapter has resolved a major concern of people jet setting across the globe. Passport Pro works in over 200 countries and regions, allowing for easy charging of your devices wherever you go. Its push button resetting fuse makes assure the adapter recovers itself within minutes if there is an overload. Say no to single phase travel adapters with the Passport Pro.
Passport Pro Resettable Grounded Travel Adapter with USB-C PD Fast Charging
X6 Power Bank and USB Hub with 45W PD & QC (20,100mAh)
A portable 21,000mAh, the X6 is a combination of a power bank and USB hub. Smart appearance and a visual display to make it easy to use and know the mode of the device. Of all portable chargers available in the market, this power bank is a versatile portable battery charger. It has been designed as per the latest charging technology and is compatible with a wide array of devices. It also supports smart watches, fitness bands and more. Another highlight of this charger is its UPS mode with pass through charging feature. With this feature, this device becomes ideal for use with home automation, security system and more.
Zendure X6 USB-C Hub Portable Charger 20,100 mAh, 45W PD & QC 3.0 Power Bank with LED Display, 5 USB Ports External Battery Pack is Compatible with MacBook, iPhone, iPad, Galaxy, Smartwatches, Fitbit, Beats Headphones & More.
While traveling, keeping devices charged should be the least of your worries! Whether you are constantly on the move or not, portable chargers and durable cords are a must have. Investing in a quality power bank and cable will add value to your devices. So, say no to all your device battery drain issues with quality products like ones mentioned above. Choose your products wisely and reap their benefits!
