Log in Sign up
Posted by Zendure Team
USB cables breakage is more common after a few months of use. This can be a very frustrating experience, particularly for those who have to replace their USB cables several times a year. Most people would love to have a strong and durable cable that will hold up for a lifetime. Now, consumers have a USB cable available to them that will meet all of their durability needs and end the frustration of cable replacement.
Apple's lightning charging cables that come with the Apple iPhone or iPad don't usually last too long so owners end up buying more than one lightning cable. Apple’s iPhones and iPads use their own Lightning connector for charging and transmission of data. You can purchase third-party cables, but they must be certified. If a cable wasn’t certified by Apple, you will typically see a warning message when you connect it.
Zendure-supercord-for-apple-charging-devices
Apple MFI Certification is important because non-certified lightning cables can be a hazard to a device. Counterfeit lightning cables can often get too hot causing damage to a device, and even destroy it. If you use an uncertified or knock-off Lightning cable, the following issues could occur: cable might become damaged, iOS device could become damaged, the connector end might not fit properly into your device, connector end might fall off, or you might not be able to charge your device.
What is Apple MFI Certification?
Apple offers an “MFi Certification Program.” “MFi” stands for “Made for iPhone,” “Made for iPad,” and “Made for iPod.”. The Lightning connector that iPhones, iPods and iPads have been using since 2012 is a proprietary connector created by Apple. Each lightning connector has a tiny authentication chip inside. This authentication chip communicates with your iPhone or iPad, which is how your device knows whether you’re using an Apple-approved cable or accessory, or one the manufacturer didn’t put through Apple’s certification program.
As part of the Apple certification approval process, a company must submit samples of their cables to Apple's independent testing facility to undergo rigorous mechanical, stress, and electrical tests. Cables made by Apple or affiliates via the Made for iPhone/iPod/iPad program (MFI) are designed to work dependably with Apple devices because they have the hardware that performs pin allocation and power management.When a company receives Apple MFi certification, it increases the likelihood that a product from that manufacturer lives up to Apple's technical requirements.
Apple-certified-zendure-charging-cableSuperCord Lightning Cable: Apple MFi Certified Cable with Lifetime Warranty
Zendure has created the ultimate durable and stylish lightning cable that comes with a Lifetime Warranty. Zendure SuperCord Lightning Cable is certified by Apple for high-speed charging with compatible Lightning devices which is up to 12W optimal charging. The cable is compatible with iPhone Xs/Max/XR/X/8/8 Plus/7, iPad Air, iPad Mini, iPad Pro, iPod Nano.
Zendure-charging-cable-for-appleUltimate Strength and Durability
Zendure reinforced the cable’s construction with advanced technology for enhanced durability and flexibility, and provide all-around protection for the whole cable, The SuperCord Lightning Cable is wrapped in nylon for added strength, and one of the key components is a resilient fiber that provides added durability. The 400D fibers reinforce the inner wiring for added strength and 1050D individual strands add durability and protection. In fact, the cable is so durable Zendure has run tests showing it can tow a car!
Zendure-supercord-so-strong-it-can-tow-a-carUltimate Protection
There is a very good reason why this Apple MFi-Certified Cable comes with a Lifetime Warranty. The Zendure SuperCord Lightning Cable passes the 50,000+ Bend Test. With reinforced cable construction, the cable is certificated by TÜV Lab, proving that it is capable of withstanding over 50,000 flexes at 180 degrees. This is ten times stronger than ordinary cables.
The Zendure SuperCord USB Cable also has superior strain relief and reinforced connectors. Made from soft and flexible material, this strain relief helps absorb stress and reinforce the junction between the cable and connector to prevent separation. As well, strong, fire resistant PVC protects the circuit board and chipset inside with a stainless steel connector. The Zendure SuperCord Lightning Cable also has a premium braided jacket which provides unparalleled protection for inner wires. You can also manage your cable neatly with the attached genuine leather strap ensuring that your cable doesn’t get tangled up.
Zendure-cord-reinforced-for-durability
A Smart Investment
Apple MFi certification ensures complete charge and sync compatibility with iPhone X / 8 Plus / 8 / 7 Plus / 7 / 6s Plus / 6s / 6 Plus / 6 / 5s / 5c / 5 / iPad Pro / iPad Air / Air 2 / iPad mini / mini 2 / mini 4 / iPad 4th gen / iPod Touch 5th gen / iPod nano 7th gen and Beats Pill+. As well, it connects to your iPhone, iPad, or iPod with Lightning Connector and charges/syncs by connecting the USB connector into your wall charger or computer. The SuperCord Lightning Cable, an Apple MFi-Certified Cable with Lifetime Warranty, is definitely a smart and economical investment.
Zendure-supercord-best-charging-cable-apple
